dear all,
I meet some difficulties in understanding what happens inside a multistage reciprocating compressor.
The problem starts from the fact that the compressor's mass flow rate aspired (value measured by a mass flow meter) is over 30% higher than the mass flow rate discharged by compressor (value provided by the manufacturer, and also calculated by having the amount of gas inside the tank in which the air is stored (PV=mRT -ideal gas equation) and measuring the time to reach from the state 1 to the state 2 we can calculate an average mass flow rate, values that are proving to be the same as those offered by manufacturer)
Normally I expect this mass flow rate being higher because the compressor is equipped with an air filter and a dryer system in order to evacuate the water condense resulting from air cooling using intercoolers, but how much? with 2-4% not 30% .
The content of water vapor in the air means almost nothing as long as in ambient conditions 1 kg of dry air contain about 10-15 grams of water vapors.
Another thing that I want to know is how could I estimate the evolution of the air temperature inside the storage vessel? considering two hypothesis: 1) the air leaves the last cylinder at a constant pressure and cooled near to the ambient temperature.
2) the discharge valve of the last cylinder works on differential pressure, and also in this case the air is cooled near to the ambient temperature.
regards,
