Hello Everyone,
I want to transfer Air with (500NMC flow rate, and 6 bar pressure) from the main header situated at a distance of 350 meter with (min available air 3000 NMC, and P=8-10 bar).
The ketch is attached..
I am thinking for using 2inch dia pipe for this purpose. I want to know how to control the Desired flow and pressure for the said 2 inch pipe if I dont install PCV.
Incase of orifice plates use, at what location and how much I should install, and how that will control these two parameters.
Your suggesstion are highly apreciated..
Designing Air flow rate system....xlsx 10.03KB 22 downloads
SAK....
