Good Afternoon
I have a question about a centrifugal pump. Why centrifugal pumps does not have relief valve????
Thank you for your answers.
Vanessa
Posted 04 May 2015 - 12:25 PM
Good Afternoon
Vanessa
Posted 04 May 2015 - 12:39 PM
Vanessa,
It might even a centrifugal pump needs relief valve at discharge, say, when the discharge line haven't been designed for pump shut off pressure and discharge line blockage to be a credible scenario...
If you see in most cases there is no relief valve at discharge line of centrifugal pumps, it's because relevant discharge lines are being designed per pumps shut off pressure and also there are adequate protection layers against discharge line blockage such as minimum flow line and FSLL for pump trip at a prespecified set point...
Posted 18 May 2015 - 12:23 AM
for me, normally centrifugal pump come together with minimum flow line and by having minimum flowline over pressure normally will not happened.
it really depends on the application of the centrifugal pump and how they protect the over pressure during design stage. some application letsay for simple not hazardous system like loading and loading pump which is manned operation, it is not protected as operation will be there during loading and unloading. some system has PT where when it detect overpressure, it will trip the pump.
For firewater pump, based on NFPA, it require relief valve especially diesel driven.
Posted 18 May 2015 - 01:26 PM
Posted 18 May 2015 - 09:54 PM
if the discharge side is not designed for pump shutoff then there can be a relief valve provided
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Psv Fire Case Relief Load CalculationStarted by Guest_mahmooddalvi09_* , 21 Feb 2024 |
Self Actuated Pressure Reducing ValveStarted by Guest_panagiotis_* , 16 Feb 2024 |
