I got a question at relief analysis for a Check Valve Failure Scenario.
Please see the sketch attached. The basic information is as follows.
* A liquid pump is used to send the product from a Surge Drum through a series Heat Exchangers and Furnace to A high pressure Vapor-Liquid operating Reactor. Two Check Valves are installed at the Pump Exit line.
* The Scenario is Check Valve Failure when high pressure vapor from reactor flow reversely through the heat exchangers, Furnace as well as Check Valves. The Vapor in the Reactor is about 400 DegC.
* The Rate Estimation of Reverse Flow is done.
The Question is,
* As the relieving flow goes through the HXs and Furnace in a REVERSE direction, how to estimate the duties in these heat exchangers and further to estimate the temperature of relieving flow?
Thank you in advance.
Invssse
