Hi all !!
I want to read about a standard refinery configuration , the various streams from CDU/VDU and where are they processed .
Can anyone share or direct me to some informative reading.
Posted 08 May 2015 - 05:49 AM
Hi all !!
Posted 08 May 2015 - 06:31 AM
There is a lot of information on the web. See for example:
http://www.api.org/e...arch2012v6.ashx
https://www.energyin...-notes-2012.pdf
http://www.statoil.c...ds/Refining.pdf
http://www.hydrocarb...-heavy-oil.html
http://www.cbi.com/i...PTQ_article.pdf
Posted 12 May 2015 - 04:12 AM
Hey Thanks for the information , Can you also share the Carbon No. of the various Stream coming out of CDU/VDU and also of the products.
Posted 12 May 2015 - 05:42 AM
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Firewater Theoretical Vs Actual FlowStarted by Guest_stu_* , 25 Feb 2024 |
