As per DEP 80.45.10.11 following stpes are involved for column simulation for relief valve. I have some doubts as follows
The procedure for steady state simulation of a fractionating column for loss of overhead
cooling (I guess this is applicable to all scenarios, please correct if i amwrong) shall be as follows:
1. Calibrate the process model of the column using normal operating conditions.- What mean by calibrate? i understand it as taking out column from main simulation model and matching all results.
2. If the column has a feed-bottoms exchanger, model it by interchanging heat between
the two streams using a specified transfer coefficient and exchanger area (i.e. set “UA”
or “U” and “A” in the simple exchanger model, do not set Q or one of the outlet
temperatures).- OK
3. Eliminate design specifications and convergence control from the model as follows.
a) Set all column heat inputs, feed and product flows at their design case values.- What mean by design case values? many times column in the main simulation model is not at its design condition.If column have some spec control on feed, product or heat input should i have to disable it? If yes then how column will converge without spec. It can give me any solution. If no then which spec should not be changed
Set the reflux rate or ratio at the design case value -Same question here. Where will i get design case reflux ratio. Should i remove spec (if there) and put re-flux ratio manually?
c) Set the reflux temperature at the design case value- Same question here. Where will i get design case value
d) Set the side draw flows (if any) at the design case value(s)- Same question here. Where will i get design case value
e) For partial condensers, maintain constant accumulator vent rate. Set the vent rate
at the design case value.Same question here. Where will i get design case value
f) Do not specify or vary parameters to obtain any tray temperatures, flows or
compositions in the distillation model. This means turning off all design
specifications, external/internal controllers, or other composition constraints
around the column- Does this mean removing all specs. But if all specs are removed, then how i can tie column. It will give me any solution.
g) Allow condenser duty and overhead product rate to vary during convergence.-OK
4. Run the column at the normal pressure.-OK
5. Ensure that the same results are obtained as with the original model, within the
calculated accuracy or convergence tolerance.-OK
6. Rerun the simulation with the overhead pressure equal to the relieving pressure (PRV
set pressure plus allowable overpressure).-OK
Apologies if i have repeated same question.
Edited by dattatray kolte, 12 May 2015 - 05:36 AM.
