Centrifugal Compressors
Started by arouna_roro, May 15 2015 05:26 AM
Posted 15 May 2015 - 05:26 AM
I my plant a two stage centrifugal compressor 1st stage compresses from 1 bat to 10 then the 2nd stage compresses from 10 to 32 , i know the inlet temperature and the outlet temperature but i suspend of the outlet temperature .
Can anybody tell me the equation i use inlet P & T and outlet P assuming that it is an isentropic compression to calculate the true outlet T to compare it with the presnet one !!
Posted 15 May 2015 - 06:18 AM
http://www.grc.nasa....ne/compexp.html
https://books.google...epage&q&f=false
To support your work.
Edited by breizh, 15 May 2015 - 12:03 PM.
Posted 15 May 2015 - 07:12 AM
P1/P2 = T2/T1
Posted 15 May 2015 - 11:29 AM
You are going in the wrong direction because you obviously don't understand gas compression - especially that used in centrifugal machines.
Centrifugals do not compress gases isentropically. They do so in a POLYTROPIC manner. Therefore, you have to use the Polytropic relationships.
Fan Laws For Centrifugal Compressors And Varying Suction ConditionsStarted by Guest_SickPuppy0_* , 25 Jan 2023 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Design Gauge Pressure Inlet To A Centrifugal Compressor.Started by Guest_Mohammad3799_* , 03 Mar 2024 |
Answered
How Does A Vsd Gas Centrifugal Compressor React To A Demand ChangeStarted by Guest_AlexNguyen_* , 08 Jun 2023 |
Answered
Effects Of Suction Pressure On Volumetric Flow Rate In Centrifugal ComStarted by Guest_AlexNguyen_* , 31 May 2023 |
