Hi everyone,
Could anyone here explain me why the outlet pipes of pumps are always designed to be smaller than the inlet?
Thanks in advance,
Trung Phu
Posted 16 May 2015 - 10:55 AM
Hi everyone,
Thanks in advance,
Trung Phu
Posted 16 May 2015 - 11:11 AM
Posted 16 May 2015 - 12:08 PM
Trung Phu,
Mostly because the fluid velocity in suction line should normally be lower than fluid velocity in discharge line to increase NPSHA and having smooth flow at pump inlet...
Posted 16 May 2015 - 12:53 PM
In addition to the answers above, see:
https://www.grundfos...siderations.pdf
http://www.pumpfunda...pump_system.pdf
Posted 16 May 2015 - 08:01 PM
Thank all for your valuable comments.
Mr. Falllah,
I also wonder whether the reducer at the inlet of pump is designed to increase NPSH or just to fit the pump inlet.
Posted 16 May 2015 - 09:25 PM
Posted 16 May 2015 - 09:29 PM
Mr. Falllah,
Posted 16 May 2015 - 09:50 PM
Posted 17 May 2015 - 12:39 AM
Mr. Falllah,
Trung Phu,
The reducer, if needed (there might be the cases in which the suction line size is equal to pump inlet nozzle size), at the pump inlet has to be considered just to fit the pump inlet nozzle size with suction line size. Obviously, it would have a negative effect on NPSHA of the pump...
Posted 19 May 2015 - 09:30 PM
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
