How To Plot The Efv Curve At The Hydrocarbone Partial Pressure To Dete
#1 mhamdi khaled
mhamdi khaled
  • 50 posts
Posted 18 May 2015 - 07:44 AM
Hello every one,
To determine the flash zone temperature of an atmospheric tower, I have plotted the EFV cuve (14.7 psi) and i determined the flash zone hydrocarbon partial pressure (19.62 psi). Now, I want plot the EFV at 19.62 psi.
How i can do it?
#2 Profe
Profe
  • 316 posts
Posted 18 May 2015 - 02:17 PM
Hi Mhamdi Khaled
For your help:
With the flash curve calculated at atmospheric pressure. To plot this EFD at any other pressure take the 50 %vol temperature, and using the vapor pressure curves for hydrocarbons (see Figure 3 .A. 1 in the appendix) read off the temperature at the desired pressure. Draw the EFV curve through this new temperature parallel to the atmospheric curve. The flash zone temperature is the temperature at the % distilled On the partial pressure curve.
According the: Handbook of Petroleum Processing by Jones, Pujadó,  Chapter 3
Attached the graph mentioned above Figure 3.A.1
Fausto
Edited by Profe, 28 May 2015 - 08:33 AM.
#3 mhamdi khaled
mhamdi khaled
  • 50 posts
Posted 18 May 2015 - 05:10 PM
Dear Profe,
thanks a lote Sir. Finally, i find the solution :)
rgrds,
Mhmadi khaled
