I am designing a condenser to condense ethylene oxide on the shell side of a shell & tube heat exchanger using cooling water on the tube side. The condenser operating pressure is 2 atm and at this pressure, Ethylene Oxide condenses at 30 deg C. No subcooling takes place in the condenser. How should I select the temperature of the chilled water to be used and what should be the allowable temperature rise of the chilled water at the outlet?
Chilled Water Temperature
Started by Light, May 19 2015 08:39 AM
Posted 19 May 2015 - 08:39 AM
Posted 19 May 2015 - 09:20 AM
If you want to keep this into a single E-type shell-and-tube heat exchanger, the maximum outlet chilled water temperature should be a maximum of 1 to 2 degrees above 30 C. The inlet chilled water temperature depends on the economics of that system.
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
