Is there a way to calculate the actual naphtha being produced by a heavy coker gasoil hydrotreating? What are the other parameters needed to do this? I have distillation data of the feed.
Naphtha Production
Posted 20 May 2015 - 02:33 AM
Posted 18 June 2015 - 12:39 AM
The actual naphtha product depends on the density of the feed and the chosen conditions of the hydrotreater. You can find some correlations in literature or assume a basis.
Posted 18 June 2015 - 04:10 AM
In the hydrotreater, sulfur is replaced by hydrogen. Sulfur compounds have higher boiling points. When they are converted to compounds freed from sulfur and replaced by hydrogen, the converted compounds will have lower boiling points. If such compounds fall in the naphtha boiling range, they constitute naphtha. So if you know the quantity of such sulfur compounds in the feed, you can get an idea on the production of naphtha.
Secondly, when coker gas oil (which contains unsaturated hydrocarbons) is treated with hydrogen, the unsaturated hydrocarbons are converted to saturated hydrocarbons which have lower boiling points than unsaturated compounds. If the coker gas oil is analyzed for such compounds, an idea can be obtained on the naphtha production.
Edited by P.K.Rao, 18 June 2015 - 07:27 AM.
Methanol ProductionStarted by Guest_Manue_* , 21 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
Reactive Distillation For Dimethyl Carbonate ProductionStarted by Guest_JakeHollier_* , 02 Mar 2024 |
Oil Production And Desalting UnitStarted by Guest_Ali4269278331_* , 25 Feb 2024 |
Sulfuric Acid Production / Partial Pressure Of H2So4Started by Guest_Jon K_* , 22 Sep 2023 |
