Design Waste Heat Boiler (Exhaust Heat From Gas Engine)
Posted 21 May 2015 - 06:22 AM
I have a gas engine that producing about 600'C of exhaust gas. If I want to design waste heat boiler that using an exhaust gas from gas engine. Does anyone have a project guide or design calculation where should I start to design waste heat boiler?
Thank you for your response.
Best regards,
Hafidh
Posted 24 July 2015 - 09:00 AM
Hafidh,
You can review the book "Steam Generators and Waste Heat Boiler: For Process and Plant Engineers", by V. Ganapathy.
I hope help you.
Napo.
Posted 24 July 2015 - 10:05 AM
Designing a waste heat boiler is not a simple task and not something to be taken on by someone with no experience, I would suggest contacting suppiers of WHRU's and getting them to quote you a unit.
Posted 24 July 2015 - 11:08 AM
I would agree with Colin. You should get advice from a more experienced colleague or work with experienced suppliers. A poor or wrong design would make you infamous and is detrimental to you at such an early stage in your career.
Posted 24 July 2015 - 11:13 AM
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Design Gauge Pressure Inlet To A Centrifugal Compressor.Started by Guest_Mohammad3799_* , 03 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Co2 Degasser Design ParametersStarted by Guest_AnnaV_* , 26 Feb 2024 |
