Could anybody advice method of sizing a liquid ring vacuum pump suitable for priming a large centrifugal pump (including connected pipe lines).
Best regard
Arun
Posted 25 May 2015 - 04:22 AM
Best regard
Arun
Posted 25 May 2015 - 06:38 AM
Hi Arun,
Sizing depends on how much time you require for priming the pump along with connected pipelines. In my plant we have cooling water pump and primming with water ring vacuum pump will take approx 5 to 7 mins. By knowing the volume of your pump & connected pipe lines and time required for primming, you can calculate the capacity of vacuum pump.
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , Today, 12:03 PM |
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
