Vent Sizing For Reactors
Posted 27 May 2015 - 01:13 PM
I would like to know the basic equations and methodology in order to design the vent system.
Posted 27 May 2015 - 02:31 PM
vnig,
Which vent type...?
A general question would have a general answer...
Anyway the flow rate and properties of the gas to be vented should be known; then the vent should be sized and configured such that in any case the reactor not to be pressurized over than its design pressure in maximum venting flow rate...
Edited by fallah, 27 May 2015 - 02:31 PM.
Posted 28 May 2015 - 05:41 AM
you are talking about vent for a reactor, the reactors i am dealing with are having emergency depressurizing system, which has control valve some time automatically actuated based on certain process upset conditions and some time manually actuated from control room by operator.
Please confirm is your system is similar.
For normal vessel the vent size is based on the volume of the vessel. few customer want it to be sized for diameter of the vessel which i believe is same to volume assuming L/D ration close to 3.
Posted 02 June 2015 - 11:02 AM
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Ro SizingStarted by Guest_T_bag_* , 27 Feb 2024 |
