Insulated Tank Blanketing
#1 Maximus85
Maximus85
Posted 28 May 2015 - 07:11 AM
Hi engineers,
I have to calculate the inbreathing flow rate of a 10000 cubic meter tank. The tank is insulated and temperature-controlled. Do you think I should consider the required flow capacity due to thermal out-breathing and inbreathing?
Thanks.
#2 proinwv
proinwv
  • 391 posts
Posted 28 May 2015 - 07:29 AM
What is the chance of your temperature control failing? What would happen if it did?
#3 fallah
  • 4,952 posts
Posted 28 May 2015 - 11:38 AM
Maximus85,
Although having the insulation can retard the rate of heat exchange between the tank and the ambient and consequently retard the rate of thermal inbreathing/outbreathing, it might the credit can't be taken for such retard due to the chance for loss of insulation...
