valve problem
I have a process problem at a valve installed at the outlet of a heat exchanger, the CV of this valve =42
the valve is dimensioned for a pressure upstream = 15bar
my problem is , we have a variation of the pressure upstream (change pompme) the pressure in the present case is 7 bar
how to check if the valve can operate without problems
(The fluid is a hot oil)
Valve Verification
Posted 30 May 2015 - 10:02 AM
Posted 30 May 2015 - 11:59 AM
If you know upstream/downstream pressure, fluid properties, and valve Cv, it is quite easy to estimate the new flow conditions. Check any valve sizing reference available online, such as http://www.documenta...1798x012_11.pdf or http://www.pro-quip....ction/SS_03.pdf
Here is an online calculator: http://www.engineeri...ents-d_277.html
ISA-75.01.01-2007 is attached for reference.
Edited by Zauberberg, 30 May 2015 - 11:59 AM.
Posted 30 May 2015 - 02:45 PM
thank you, interesting!!!
but what i didnt understund is:
the CV given in the data sheet , is it a tsandard value used to be controlled by the new calculated CV??
Posted 30 May 2015 - 03:06 PM
Cv of a given valve is constant number. It is independent of upstream and downstream conditions, and of fluid properties.
Posted 30 May 2015 - 04:39 PM
well what about this relation :
Q=Cv sqrt(dp/G)
here Cv is depends on the flow rate and the pressur
so how its independent oof upstream conditions??
Posted 30 May 2015 - 04:56 PM
Please read the definition of the valve Cv in the references I posted. We are wasting time here.
Posted 31 May 2015 - 02:19 AM
ahhahaha ok , sorry i understood it
thank you again
by the way , i didnt wast the time and sorry if i did that to u
thank you again again!!
Posted 31 May 2015 - 02:38 AM
It is a waste of time in every case when people want somebody else to digest all the information and present them the final result (or explanation) in 2-3 sentences, so that they themselves do not need to make any effort beyond that point. What they do not realize, however, is that it is impossible to become a good engineer if they expect to be spoon-fed for every problem or subject they encounter.
You came up with additional question only 2 hours and 45 minutes after I posted a plentiful of data in my first post. I seriously doubt you have taken the time to read all links and attachments within this period. You wouldn't ask again about the valve Cv if you have read those links and attachments, because the answer is already there.
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Self Actuated Pressure Reducing ValveStarted by Guest_panagiotis_* , 16 Feb 2024 |
Kvs Value Control ValveStarted by Guest_panagiotis_* , 05 Feb 2024 |
