How to estimate VAM machine capacity if heat sources are available? e.g. we have got 110 DEG C hot condensate of 100 M3/hr. How much TR can be generated, and another thing what is the outlet temperature of condensate after VAM ? Any help is most welcome...
Vam Unit Capacity Estimation
Started by ASH25320, Jun 01 2015 12:10 PM
Posted 01 June 2015 - 12:10 PM
Posted 01 June 2015 - 01:12 PM
Posted 01 June 2015 - 07:54 PM
Ash,
You probably understand what you asked, but I have no idea what you are talking about. You have to explain it in more detail, and what does VAM stand for? Vinyl Acetate Monomer is one interpretation I am familiar with. And, TR?
Edited by latexman, 01 June 2015 - 07:55 PM.
Posted 02 June 2015 - 10:21 AM
sORRY ,, vAPOR aBSORPTION mACHINE (VAM) uses waste heat to produce regeration, TR is Tons of Refrigeration....
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Need Help In Calculating Ammonia Slip In Scr Unit.Started by Guest_Redbull010203_* , 11 Mar 2024 |
Oil Production And Desalting UnitStarted by Guest_Ali4269278331_* , 25 Feb 2024 |
