Greetings,
I have a Seal drum that is 8' in diameter and 12' in height. Inlet pipe is 42" and has a weir that separate the wet side from the dry side. The inlet pipe has a seal of 32" in the wet side of the drum.
My question is how can I calculate the drop pressure and the back pressure in the Seal Drum and what formula to use?
Thank you in advance
