Sir, we have a naptha hydrotreator in which feed ( naptha + recycle gas) enters an exchanger train ( say A, B, C......H=total 8) shell side then to a furnace and then to a reactor and reactor O/L goes into tube side of the train( final tube side O/L is 102 deg celcius) and then to air fin cooler and a seperator (operating pressure=24.6kg/sq.cm)..Now we inject fresh makeup H2(300Nm3/hr) available at 37 Kg/sq.cm and a temp of 32 deg celcius at the Recycle gas suction KOD. can we inject fresh Hydrogen makeup at the exchanger tube side outlet ( upstream of air fin cooler at which temp is 102 deg celcius and a pressure of 26.5 Kg/sq.cm) instead of making up at Recycle gas compressor suction KOD? iam asking this because one exchanger (A) has been removed due to exchanger tube fouling and resulting in 102 deg at Upstream of air fin cooler which is difficult to cool by air fin cooler in summer.now air fin cooler outlet is 78 deg celcius. and there is no trim cooler between AFC and seperator.
Edited by kirang11, 03 June 2015 - 07:05 PM.
