Does anybody apply thermal relief valve (TRV) for vessel and tube overpressure protection? (Not rupture pin valve or fusible plug) anybody met TRV in service or in maintenance? Is it frequent in application? Does anybody have a worth literature about this?
Thermal Relief Valve. Faq
Posted 18 June 2015 - 04:33 AM
Posted 18 June 2015 - 04:45 AM
shvet,
Yes, if the cause of over pressure would be liquid thermal expansion...
Posted 18 June 2015 - 06:57 AM
If liquid can be trapped in a full liquid system (equipment of pipe) thermal expansion of liquid shall be studied. to protect pipes and equipment usually TRVs are used.
Posted 18 June 2015 - 11:47 PM
The sourse of overpressure during liquid thermal expansion is rise of temperature caused heat input. If liquid is heated from for example 0 to 30 °C it is the same case liquid is heated from 100 to 130 °C. In this case it means TRV has to be conventional PSV with set pressure = design pressure of pipe.
I'm talking about special products - for example overpressure of vessel with vapor (no liquid). It's not effective to apply conventional PSV because of overheating and gaskets rupture.
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Thermal FuseStarted by Guest_Dr_bigfoot_* , 09 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
