Gas Turbine Performance Curves
Started by CHEMSTRONG, Jun 25 2015 04:52 PM
Posted 25 June 2015 - 04:52 PM
Dear Sir,
I have Gas Turbine Performance curves in the form of Output Shaft speed, rpm ( x axis), % reference vs shaft power, % Reference( y axis) at various heat rates, % reference at various ambient temps. Separate map for each ambient temp...PFA GT Performance curve at particular temp of ambinet and it is also available for other temps,
I want to show the effect of ambient temp change on gas turbine performance in simulation.How to do it ? How to calculate turbine efficiency from heat rate? Also tell me Shall i give speed from this curve to speed controller of turbine?
Can u please guide me ?
Chetan
Posted 02 July 2015 - 04:30 AM
I think you might find the following books useful for you.
http://www.amazon.co...n/dp/0123838428
http://www.amazon.co...s and Practices
Posted 02 July 2015 - 06:36 AM
You need to obtain a power correction vs. ambient temperature (inlet air temperature) curve from the turbine manufacturer.
Turbine Efficiency (%) = 3412 (Btu/kW) / Heat Rate (Btu/kW)*100%
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Variable Speed Pump CurvesStarted by Guest_panagiotis_* , 27 Jan 2024 |
Steam Turbine Extraction And Letdown ValveStarted by Guest_zavtranguyen_* , 07 Oct 2022 |
Control Limits And Key Performance Indicators (Kpis)Started by Guest_CHEMSTRONG_* , 13 Aug 2022 |
Gas Turbine Simulation, Part-Load OperationStarted by Guest_twana_* , 21 Jul 2022 |
