A geothermal plant pumps water at 15 degrees celsius into the ground. The water travels through the pipes underground before returning to the surface at a temperature of 90 degrees celsius. If the efficiency of the plant is 10%, how much water must be pumped into the ground every second for the plant to generate 1MW of power?
