Geothermal Power Plant Problem
#1 geo123
geo123
  • 42 posts
Posted 04 July 2015 - 08:42 AM
A geothermal plant pumps water at 15 degrees celsius into the ground. The water travels through the pipes underground before returning to the surface at a temperature of 90 degrees celsius. If the efficiency of the plant is 10%, how much water must be pumped into the ground every second for the plant to generate 1MW of power?
#2 geo123
geo123
  • 42 posts
Posted 04 July 2015 - 09:06 AM
I used Q=cm(deltaT)
and
n=W/(Q1)
Q=energy input
W=work done of the engine
n=efficiency
c=energy gained per second
delta T= temperature difference
m=mass flow rate
#3 geo123
geo123
  • 42 posts
Posted 04 July 2015 - 09:28 AM
(Q1)=1MW/0.1=10MW
m=(deltaQ)/c*(deltaT)=(10^4kW/(4.2kJ/kg*K))*(75K)=1.79*10^5kg/s
#4 geo123
geo123
  • 42 posts
Posted 04 July 2015 - 09:29 AM
I want to know if I've done it right or wrong?
Edited by geo123, 04 July 2015 - 09:29 AM.
#5 breizh
  • 6,347 posts
Posted 05 July 2015 - 01:40 AM
geo 123,
Redo the math :should be 31.89 kg/s   ;Q=m*cp*dt >>> m =Q/(cp*dt)
Edited by breizh, 05 July 2015 - 05:40 AM.
#6 Art Montemayor
  • 5,780 posts
Posted 05 July 2015 - 03:58 PM
Geo123:
Stop making multiple postings of the same topic - especially in different Forums.
READ THE FORUM GUIDELINES.  If you persist, I'll have to take remedial action that won't sit well with you.
Thank you.
#7 geo123
geo123
  • 42 posts
Posted 11 July 2015 - 08:10 PM
I'm sorry about this and I will not make anymore multiple postings of the same topic - especially in different Forums.
Thanks for the help.
