We have a steam driven turbine with steam inlet pressure of 39.6 kg/cm2 and exhaust pressure of 4.5 kg/cm2. It is coupled with a pump which is used to deliver steam condensate from common condenser at around 100 Tph. Pump is submersible type with suction pressure of -0.68 kg/cm2 and discharge pressure of 6.5 kg/cm2.
Level of condenser is controlled by level control valve located at d/s of pump. Normally it control the level at around 45 % valve opening.
Turbine rpm are normal running at around 2790.
From last few days we have been experiencing variation in turbine rpm of around 100 to 150 rpms, with the increase in speed of turbine; variation reduces but after some time it again appears and the problem persist. Also initially when the level control valve was put on manual mode from auto turbine variation stopped but as soon as it was put on auto, when ever opening of valve increases above 55 % variation in turbine rpm again appears.
We have checked the TTV of the turbine, no abnormality observed. Preventively its oil was replaced. Also we have checked the turbine in decoupled condition and it shows no variation, but in coupled condition and with level control valve on auto with more than 55 % opening; turbine shows variation in rpm and slowly level increase in condenser starts which causes higher opening of level control valve and difficulty in level controlling.
Turbine remains smooth if the level control valve opening is around 45 % with valve on auto mode.
I need to ask that if some body can tell me that why turbine is showing variation in rpm if level control valve opening increases beyond 50 % where as around 45 % turbine remains smooth. what could be the possible problem.
