Vaccum Tower Stripping Steam
#1 franchescamarie
franchescamarie
  • 15 posts
Posted 09 July 2015 - 09:48 PM
Hi!
I would like to ask if it is acceptable to use saturated stripping steam instead of superheated stripping steam for a vacuum tower? Wouldn't this pose any damage to the vacuum tower internals? What happened is that the stripping steam production of vacuum pipestill unit (by steam generation section) is lower than required so we would like to admit the saturated stripping steam from header.
Superheated stripping steam being produced has a temperature of 350 deg C and a pressure of 450 KPag.While saturated steam is 150 deg C/400 KPag.
Thank you so much!
Edited by franchescamarie, 09 July 2015 - 10:13 PM.
#2 fallah
  • 4,954 posts
Posted 09 July 2015 - 11:25 PM
Effect of lowering stripping steam temperature, 350 C to 150 C, on tower performace should be investigated for your case; but in general saturated steam could be used as stripping steam provided that a knock out pot to be considered at upstream of steam inlet into the tower to remove any condensate droplet. This is to be done avoiding any damage to the vacuum tower internals...
#3 Zauberberg
Zauberberg
  • 2,727 posts
Posted 10 July 2015 - 02:30 AM
Saturated steam should be avoided, due to likely condensation as a consequence of direct heat transfer inside the tower. Each and every stripping steam application uses superheated steam.
