Psv For Pig Launcher / Receiver
#1 mosayef
mosayef
  • 33 posts
Posted 17 July 2015 - 09:44 PM
dear all,
i want to ask about sizing PSV for Pig Launcher / Receiver. i want to ask about the governing scenario for sizing PSV, commonly it is sized based on fire case scenario as a governing case, do i need to consider blocked discharge case ? why ?
thanks
#2 fallah
  • 4,953 posts
Posted 17 July 2015 - 11:17 PM
mosayef,
Depending on the conditions, you might or might not need to consider blocked discharge case for pig launcher. Then please upload a simple sketch of the system along with the relevant info to get the response....
#3 mosayef
mosayef
  • 33 posts
Posted 18 July 2015 - 09:37 PM
http://postimg.org/image/64txjalpj/
dear fallah,
that is the pig that i asked. i hope you can help me
#4 Chirag Baravaliya
Chirag Baravaliya
Posted 23 July 2015 - 12:34 AM
Generally fire case is not aaplicale to Pig Launcher/Receiver as it is extended piece of pipe not equipment . Becase, it is designed as per pipiline code (B31.3 or other code depend on service), Clause 4.4.12.1.1 of API 521, Sixth Edition, Jan-2014 states that fire case is not applicable to piping.
Based on this you can avoid fire case and consider only thermal expansion of fluid due to solar radiation only.
#5 breizh
  • 6,340 posts
Posted 23 July 2015 - 12:55 AM
Hi moyasef ,
Consider the literature attached , you will find good information .
Hope this helps
