Good Morning.I'm Rotating Equipment Engineer.
I have a centrifugal compressor, 3 stage (API 617) for CFP off gas service which is now required to be used for another service.
Existing Conditions:
Rated Flow at inlet flange : 31320 kg/h
MW: 24.10.
Suction pressure:10.03 kg/cm2a
suction temperature:40 deg C
discharge pressure : 16.5 kg/cm2a
discharge temperature : 73.8 deg C
speed : 13071 rpm
shaft power at coupling : 588 kW
Ploytrophic head : 54.71 kJ/kg
Ploytrophic efficiency : 82.4%
Motor Rating : 660 kW
New Condition :
Rated Flow at inlet flange : 50000 kg/h
MW: 57.2.
Suction pressure:2.373 kg/cm2a
suction temperature:17.87 deg C
discharge pressure : 7.103 kg/cm2a
discharge temperature : 56.6 deg C
Gas power : 797 kW (as mentioned in PDS).
My Query is before to going to OEM what can be the preliminary adequecy check that can be done and how?
Which are the points needs to checked.Request to provide your expert advise.
If any other input in addition to above is required please do let me know.
Choudhary
