hello there. Just wanting to check if there are studies already on the number (and technology/complexity) of oil refinery process units that one process engineer can effectively handle. I am reviewing the current manpower of our process engineering department and would like to know if the current manpower count is really capable to handle the task. Sorry this is not typical "chemical engineering" question but would appreciate if someone can share in case there are studies out there related. THank you.
Oil Refinery Process Engineer
Started by cjre2, Aug 12 2015 03:17 AM
Posted 12 August 2015 - 03:17 AM
Posted 12 August 2015 - 11:21 AM
Hi CJRE2
My vision:
To specialize in refining processes, a chemical engineer is fine, but requires training in relation to oil refining, which provide companies specializing in refining and design. Information that can be obtained through Google looking like "refining process engineering training" . Some are online or classroom such as UOP (Universal Oil Products) and others are engaged as the case of IFP (French Petroleum Institute) but by checking the website you can get a better picture of the scope of each option.
In my case I worked in an oil refinery and took the course of UOP which broadened my vision as a chemical engineer, focusing on the oil refining process that are not reviewed in the curriculum of Chemical Engineering. The course was attended by about three months. (Long long time ago). Today varies between 45 days and teaching aids are the latest generation. When I took the course pen and paper and a scientific calculator, compared with simulators and packages physicochemical properties currently available was used.
Ultimately it opens up a world of possibilities to Che Eng.
I think that will be useful for you.
For details look the following link: https://www.honeywel...on- seminar.pdf
Fausto
My vision:
Fausto
Edited by Profe, 12 August 2015 - 11:30 AM.
Posted 12 August 2015 - 01:55 PM
You might first want to develop job descriptions for the positions in question. Then it should be a simple matter to translate these into staffing positions.
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Let Down Vessel In Methanol ProcessStarted by Guest_Manue_* , 21 Mar 2024 |
Electrical Inputs From ProcessStarted by Guest_Chari_* , 06 Feb 2024 |
Recycling Of Working Solution In The Anthraquinone ProcessStarted by Guest_Has2riasat_* , 01 Feb 2024 |
