A tank
Edited by Ankit_Kumar, 02 December 2016 - 03:02 PM.
Posted 17 August 2015 - 03:50 PM
A tank
Posted 17 August 2015 - 04:37 PM
As I said earlier, first check the vents for faults or improper set points.
Posted 18 August 2015 - 06:14 AM
PVRVS were checked & found ok. Set point is 150 mm WC
Posted 20 August 2015 - 08:10 AM
Well that is 5.9" wc which is not unusual for a tank blanketing setpoint. However, you stated that the vents did not actuate. So that suggests that the tank failed at less than this pressure. Do you agree?
Posted 23 August 2015 - 06:58 AM
I didn't get what you want to say regarding 5.9 " WC blanketing set point.
Yeah apparently it means tank failed at less than this pressure.
Posted 23 August 2015 - 09:56 AM
You said that the vents were functional, did not actuate, and the set point was 5.9" w.c. This is not an unusual situation.
So, since the vents are okay and the set point is not unusual what that says to me is that the tank failed due to a pressure less than 5.9" w.c.
The next question for me to have answered is that should that tank have not failed under a pressure of 5.9"w.c.? Then,
What pressure should that tank have been able to withstand?
Was there a mechanical fault in that tank?
Possibly the system would have survived if the vents were set at a lower pressure.
Possibly that tank and that tank design was inappropriate for the application. ?
You see that you have a lot of questions to answer before moving forward with new or repaired equipment.
Best wishes to you.
Possibly that tank was not designed properly?
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
