Performance Test Of Pump
#1 m42364236k
m42364236k
  • 94 posts
Posted 17 August 2015 - 10:48 PM
Dear colleagues
Good day
I have one question about pump tests:
As we know all test of pump will be done by water
My question is:
If they test with water, how we can compare it with HC fluid?
For example for pump which work in oil and gas industry and when vendor give us the power -Q or h-Q and …
Those curve have been generated from water how we can compare it with actual fluid?
Second question:
All data in vendor data sheet are based on actual fluid or water?
If mention data are based on actual fluid ,how we can test it on vendor factory?
Best Regards
Mike
  • 6,334 posts
Posted 17 August 2015 - 11:22 PM
http://www.pumpfunda... total head.pdf
Consider the resource above .
Hope this helps
#3 m42364236k
m42364236k
  • 94 posts
Posted 18 August 2015 - 03:14 AM
Dear breizh
Thanks for your useful resource
One of my question is remain
 When we have performance curve of pump and also the pump data sheet with hydrocarbon fluid
Can we check the data sheet parameters such as NPSH, POWER,HEDA
With vendor curve?
or we should consider the correction factor first and after that check with vendor curves
#4 breizh
  • 6,334 posts
Posted 18 August 2015 - 03:35 AM
Mike ,
NPSHA and Power are depending of your fluid properties , this means that you need to perform correction . I don't know the meaning of HEDA.
http://www.mcnallyin...html/11-12.html
Hope this helps
Edited by breizh, 18 August 2015 - 03:40 AM.
#5 m42364236k
m42364236k
  • 94 posts
Posted 18 August 2015 - 10:34 AM
thanks again and sorry about my mistake ,it was HEAD ,
as i understand vendor give us the performance test based on water with density of 1000kg/m3
when we have hydrocarbon with density of 850 kg/m3
How we can compare  the NPSH curve or head curve and power curve with our data sheet to assure vendor data on curve are correct
or how we can consider the correction factor
as i know we just have correction factor for viscosity
THANKS IN ADVANCE
mike
#6 fallah
  • 4,951 posts
Posted 18 August 2015 - 10:57 AM
mike,
Yes, you might just have a correction based on viscosity if it is so high...
#7 breizh
  • 6,334 posts
Posted 18 August 2015 - 06:10 PM
Mike ,
For viscosity correction  refer to the booklet attached (KSB) .
Note : a lot of materials concentrated in a single document .
hope this helps
Edited by breizh, 18 August 2015 - 08:09 PM.
