I am trying to estimate the ethylene flash gas generated by initial cooldown of an ethylene tank and associated piping. Please could anyone advise on the approach.
The conceptual approach I have taken is to calculate the metal mass of the tank and the associated piping. Assume that the initial temperature of metal mass is 40 deg. C ( assumed average ambient temp. ) and the required final temperature is -104 deg. C. Assumed that the cooldown process is to completed in 24 hours. Based on this, I calculate the heat extraction rate ( mass x specific heat x delta temp / time (24 hrs)). I use the ethylene latent heat of vaporisation at a mean temperature of - 32 deg. C to calculate the vapour generation rate.
