Hi im having a problem on how should I start my design of an ion exchange column. I need to reduce the concentration of Calcium and magnesium in the brine solution to 20ppb using an ion exchange column. Here is my material balance for it http://prntscr.com/88ovig. I will be exchanging sodium ion for this one. The resin type that i will be using is a chelating resin of micro porous structure with polystyrene matrix cross-linked with di-vinyl benzene substituted with weakly acidic aminophosphonic active group as recommended in my reference. My problem is idk where to start the design, equations I need to use and stuffs. I know you need to calculate the bed volume and regeneration time.
Thanks in advance, whoever can help me
-jeffrey
