I need to design vent size for atmospheric tank, cause the tank have a thermal shock from 95° to 4° C due by CIP cycle with washing at 95°C and quickly cooling with water 4°.
Posted 28 August 2015 - 10:28 AM
Posted 28 August 2015 - 10:59 AM
How about filling and emtying rate; don't you think the worst case for tank vent to be filling or emtying rate not thermal breathing?
Posted 28 August 2015 - 11:25 AM
Would the thermal cycle occur simultaneously with any liquid transfer?
Posted 29 August 2015 - 03:33 AM
i checked filling and empty rate with API 2000, but I need to be ensure that is enough for thermal variations
Posted 29 August 2015 - 03:42 AM
I have CIP cycle when tank is empty, is a step between every process cycle,
I have two opening the vent and outlet connection, but I think is better to consider only vent area, cause after washing at 95°C I have cooling with water at 4°C, so there is formation of steam and then condensing.
Posted 29 August 2015 - 03:57 AM
You should estimate the rate of condensation for cooling with 4 C water after washing at 95 C. If the tank is designed for full vacuum condition there would be no concern. Cooling procedure (internal or external, spraying water or ...) would be helpful for mentioned estimation which is lacked in your explanations.
After above mentioned estimation the proper vent size for handling such vacuum can be calculated.
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Thermal FuseStarted by Guest_Dr_bigfoot_* , 09 Apr 2024 |
