Compressor Dynamic Simulation
Started by walidd_23, Aug 31 2015 03:35 AM
Posted 31 August 2015 - 03:35 AM
in our gas compression and reinjection facility, unexpected changing of Inlet gas composition has occurred ( the gas became leaner (M=22<< M design=27). wich routed to an effective influence of outlet pressure and compression system.
I am asked to model the Dynamic compression system , and study the behaviour of the compressor ( anti-surge..) with the new parameter and different scenario ( shutdown , decreasing of flow rate...ect)
My questions are:
1/ Can we use the same curve system of the compressor for the new gas composition.?if not how can we estimate new curves?
2/ how can we resize the surge valve?
Walid,
Posted 31 August 2015 - 07:09 PM
Polytropic head is a characteristic of the machine, not the gas. And you should engage the services of one who is skilled in the art of compressor modelling.
Posted 02 September 2015 - 03:47 AM
Thanks Bobby
What confused me that I found in compressor datasheet tow system curve of tow diffrent moleculair weight M=25 and, M=27 .
can you give me the procedure to size a surge valve ?
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
Co2 Removal Membranes Between Compressor StagesStarted by Guest_Sinclc_* , 26 Mar 2024 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
