Hi Folks,
I would like to know which two phase flow (gas-Liquid) correlation is usually recommended for modeling the flare system hydraulics (which has high pressure and velocity)?
Thanks,
Amin
Posted 03 September 2015 - 04:03 PM
Hi Folks,
Thanks,
Amin
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
