a psv whose vent returned to the tank from which the pump has sucked. There is a particular reason for this assembly?
It is not so good idea to return psv disharge back to tank which the pump has sucked.
Just imagine: you have psv, usually it is spring tipe and it discharges only after pressure drop across psv rises more than:
psv spring set pressure < pump discharge - tank normal pressure
Then some continguency occcurs and pressure in tank rises and tank psv dicharges. Pump remains on line but if operator closes shut-off valve then pump psv must open and protect equipment. But pressure drop across pump psv remains the same as before continguency occurs. And then pressure rises up to:
tank psv pressure (fully open) + pump shut-off head > pump psv set pressure
The typical system (from my personal experience) is to discharge psv in pressure independent system (tank).
Edited by shvet, 25 September 2015 - 11:03 PM.
