for a natural gas mixture with large fractions of heavy components (C6+) I get different (> 8 K) results with the Peng Robinson and the Extended Peng Robinson models available in Prode,
a laboratory chilled mirror returns intermediate values (but close to Extended Peng Robinson),
Prode is connected to the DCS and calculated values are stored (dew point being a contractual specification).
It seems that heavy fractions have a large influence on dew point , Prode allows to adopt different rules to estimate C6+ and heavier fractions (50%, 50% etc.)
there is a discussion in GPA but a detailed procedure is not given,
can you suggest a step by step procedure ?
Dew Point ( Natural Gas, Heavy Components Fraction ) With Prode
Started by mgerian, Sep 29 2015 02:20 AM
dew point natural gas heavy components fractions prode
Posted 29 September 2015 - 02:20 AM
Posted 29 September 2015 - 02:58 AM
I guess Prode is connected to a GC (for gas analysis),
if that is the case you can adopt the procedure discussed in Prode Industrial Interface manual,
you can split to predefined fractions of C6, C7, C8, C9 or heavier components,
I don't know of a specific procedure to identify the different fractions,
have you considered to use Excel (solver) Optimizer to regress the fractions to a table of measured values ?
That could be a solution but others are available...
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Rating Of Existing Condensate Fractionator With New Heavy CondensateStarted by Guest_adnanaslam1988_* , 03 Feb 2024 |
Multiple Effect Evaporator Calculation With Multiple ComponentsStarted by Guest_addiesalsabil_* , 13 Jan 2024 |
Conversion Of M3 Of Natural Gas To M3 Of LngStarted by Guest_sachico28_* , 30 Sep 2023 |
