hello,
i try to calculate wall thickness of tank.i find expression;
S=Max Allowable Stress Value
Ej=Weld Joint Efficiency
How can i find "S" and "Ej" for CarbonSteel?
and What is "Cc" I Dont know.
Question About Tank Thickness Formula
Posted 03 October 2015 - 04:25 PM
Posted 03 October 2015 - 06:23 PM
You should start by studying strength of materials and other materials such as "Pressure Vessel Handbook" by Eugene F. Megyesy. Look for this text book at Amazon Books in the Internet.
I have posted a lot information - including Excel Workbooks dedicated to the calculation of pressure vessels - and this all can be found by using our SEARCH machine.
Posted 04 October 2015 - 12:33 AM
Let you consider the documents supplied by Art over the years .
http://www.pveng.com...DesignTools.php
Good luck.
Edited by breizh, 04 October 2015 - 12:34 AM.
Epc Basic QuestionStarted by Guest_poojabathula369@gmail.com_* , Today, 03:15 PM |
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Overpressure Scenario QuestionStarted by Guest_panagiotis_* , 08 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Asme Code For Fiberglass Pressure Tank FeaStarted by Guest_Pheeto_* , 13 Feb 2024 |
