It should be sized based on present pump' flow rate and head and also the rate by which the sump is to be filled with incoming fluid...
thanks a lot for your reply dear fallah
The incoming fluid to the pit and thereby to the sump is possible raining water and possible oily water during washing or maintenance of equipment in the pit. Should i consider also these fluids flow rate in sizing of the sump (not pit i mean, only sump of the pump) or not? I mean, does these flow rates affect only on volume of the pit? or sump dimension will also affect from these flow rates?
On the other hand my question is about function of the sump. should it have only suitable size for pump or it should have suitable size to handle raining and washing water, too?
Edited by omids969, 05 October 2015 - 04:55 AM.
