Hello every1,
I tried to search for a good documentation on hsysy optimizer (a detailed one) but couldn't find anything. In case you got a useful document on hysys optimizer can you share it?
Here are some related questions:
*For example, after defining the constrains, you can change the penalty value (it has a default of 1). what's the effect of changing the penalty value (whether increasing/decreasing it)?
* In the parameters tab, what's meant by (shift A/shift B )?
* Then, in the monitor section and after starting the optimizer, the values of the design variables and the objective function will be updated after each iteration. Also, the some values (related to) the constrains appear in the monitor section (assuming a constrained function). What do these values represent? they are related to the constrains but not the exact values as the constrains.
I appreciate your prompt response.
Edited by Bal, 10 October 2015 - 07:24 AM.
