Control Valve Pressure Drop Maximum Case
control valve pressure drop maximum case 10 psi
#1 Diep Thanh
Diep Thanh
  • 15 posts
Posted 19 October 2015 - 01:56 AM
A liitle bird told me that a valve should be designed to use 10-15% of the total friction loss or 10 psi, which is greater. Could you guys please explain more about that?
What will be happend if I chose the pressure drop of CV smaller than the value ( e.g. 1 psi) Is it related to lift ratio and Cv?
Thank you for your time!
#2 Zauberberg
Zauberberg
  • 2,727 posts
Posted 19 October 2015 - 05:19 AM
Refer to Post #2 and the attachment in the thread http://www.cheresour...c-calculations/and come back in case of additional queries.
#3 Diep Thanh
Diep Thanh
  • 15 posts
Posted 19 October 2015 - 09:45 PM
Thank you for the sharing Mr.Zauberberg. However, I am concerning about the pressure drop of CV at Min and Max Case. In Nor case, I believe we are using the same rule: DP of CV should be equal or exceeded the 50% of friction loss. But how about Max. Case? They recommends 15 psi at max case. But how that value come from? What is disaster when I specify a valve at max. case 1 psi only? I will have a large control valve definitely. It will be good to control a max flowrate because it requires a lower lift ratio , right?
Please correct me if I'm wrong.
Thank you very much!
D. Thanh
