Volume Inlet And Outlet Bitumen Unit
Posted 06 November 2015 - 12:15 AM
Is it true?
Is the inlet volume and outlet after they inject air to vaccum bottom must be the same?
Posted 06 November 2015 - 02:58 PM
In a bitumen blowing unit typically 2 - 3 wt% of the feed will be lost due to oxidation (hydrogen burnoff).
Moreover the density of the bitumen will typically be 1 % higher than that of the residue feed.
Both numbers depend on the grade of bitumen that is being produced.
Together that results in a volume decrease of typically 3 - 4 %.
So 5000 BPSD residue can indeed reduce to 4800 BPSD bitumen, defined at the same temperature.
Note also that your residue flow meter as well as your clients bitumen flow meter have an inaccuracy.
Posted 07 November 2015 - 04:48 AM
Thank you ...
Can u tell me your reference data?
Posted 07 November 2015 - 10:58 AM
See attached page 134 from book Petroleum Fuels Manufacturing Handbook:
p134 from Petroleum Fuels Manufacturing Handbook.jpg 70.47KB 4 downloads
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Outlet Temperautre Of ReboilerStarted by Guest_hysyshunter_* , 18 Mar 2024 |
Need Help In Calculating Ammonia Slip In Scr Unit.Started by Guest_Redbull010203_* , 11 Mar 2024 |
Design Gauge Pressure Inlet To A Centrifugal Compressor.Started by Guest_Mohammad3799_* , 03 Mar 2024 |
Oil Production And Desalting UnitStarted by Guest_Ali4269278331_* , 25 Feb 2024 |
