Hi! I'm simulating a vinyl acetate plant using ASPEN Hysys V8.6. I have a mixture of acetic acid-H2O-vam and in my first distillation column, I have already separated acetic acid leaving me with a vam-H2O mixture. The vam-H2O mixture will then enter another distillation column. But this time, I'm not able to purify vam to 99.99%. Do you guys have any tips for me to increase the purity?
Distillation Column: Increase Purity In Hysys
Posted 15 November 2015 - 12:04 AM
Posted 15 November 2015 - 07:46 AM
It is not possible to purify vinyl acetate higher than 92.7%wt from a mixture with water, at 1 atm absolute, by simple distillation because of the azeotrope.
The ternary system acetic acid - water - vinyl acetate presents the above mentioned azeotrope at cca 66 °C and, even more, a L-L domain (see attachment). Fortunately, the azeotrope is heterogeneous and, therefore,
by adding a decanter downstream the condenser and recycling a part of the organic phase (aqueos phase is not turned back in column) you will be able to reach the desired 99.99%wt (?) acetate purity.
Lucian
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
Reactive Distillation MtbeStarted by Guest_Michael Mitra_* , 15 Mar 2024 |
Vacuum DistillationStarted by Guest_hysyshunter_* , 12 Mar 2024 |
Distillation Column DiameterStarted by Guest_refluxraider_* , 12 Mar 2024 |
