How do you estimate the cost of electricity for equipment?
In Turton's book (Analysis, Synthesis and Design of Chemical processes), 3rd ed., there is a table in chapter 8 (Table 8.3) and it lists type of utility with its cost per common unit. I tried to find the basis of these numbers, but I couldn't.. like what's the ref.? what's the yr at which those cost were obtained?
Then I checked chemical engineering resources website, and I found a paper (Engineering practice) on estimating the utility costs by :Gael D. Ulrich and Palligarnai T. Vasudevan. The corrolations given in the paper relates the cost of electricity to the CEPCI and to the fuel cost, for example (they do make sense )
Now, I tried to retrieve the values given in turton using those equations: for example, the cost of electricity is:
1.1e-4*(CEPCI)+0.011*(fuel cost ($/GJ))= $/kW-hr
Where
CEPCI in Turton 3rd ed. is 397,
fuel cost from Turton, table 8.3 (assuming natural gas) is 11.1 $/GJ,
The cost from the correlation is 0.16 $/kW-hr, but the cost of electricity in Turton table 8.3 is 0.06 kW-hr.
If coal was used instead of natural gas, the value from the correlation would have approached the value in turton's table..
What do you suggest???
In turton, I don't know the basis upon which those numbers have been estimated. Also, I don't know the type of fuel used to generate the electricity and from the electrical utilities are supplied......
Shall I rely totally on that paper? what about the values in Turton??
