All,
My questions may be very basic for some but need to ask.
I have asked similar question in the past (see link below).
Background: The company i work for produces PET resin. Acetaldehyde (AA/Ethanal) is a byproduct of the esterification reaction of ethylene glycol and TPA (Pure terephthalic acid). the AA needs to be stripped downstream. The stripper column has not be performing well and my superior wants to recirculate bleach through the column to try to clean the column. the stripper column is a packed column and the temperatures set points are kinda questionable in my opinion ("we have always run it this way" is what i hear). the AA+water is fed to the top and Air + Steam is fed from the bottom. I thought it be a good idea to run a simulation to do some case analysis. questions:
1- Did any of you design and operate such column if so how do you operate the column?
2- Have you ever clean the column with bleach? if so how effective was it?
3- While setting up my simulation, i realized i have to enter the # of tray in the Redfrac even though reboiler and condenser option was selected to none. In Aspen Plus how does one convert HETP to # of tray? in the rating option I entered the known HETP of column but the number of trays i don't what to enter.
Any help will greatly be appreciated
http://www.cheresour...-packed-column/
