Hi All,
I am seeking your assistance, I am interested in controlling the pH of industrial water by manually dosing calculated amounts of Acid/Base the effluent contains variety of organic as well as inorganic pollutants. I have taken into consideration an automated system but that is just not economically feasible for the process.
I have been using the formula C1V1 = C2V2 in order to determine the amount of volume to add into the water to be able to increase the pH from low to a higher pH and in order to determine the H+ ions in the water i have been using pH = - log[H+] and has been working slightly well in the lab as it does give me the amounts which i should add to increase the pH and when it comes to decreasing the pH not really well. And when it comes to applying this formula in the industrial process it does not work at all as it gives me very high volumes higher than the actual size of the treatment process.
Are the any suggestions what other formulas I can use to actually do this task successfully at an industrial scale.
