Rogor:
I don’t believe anyone can furnish you with an operating, startup or shutdown procedure without having a detailed, as-built, P&ID (Piping & Instrumentation Diagram) and the ability to discuss a detailed Hazop. Your PFD (Process Flow Diagram) is too simplified for technical or operational discussion. We are unable to accurately interpret what is the intent, design, and scope of the system you show.
For example, you show something that cannot be a steady-state process: a steam-heated exchanger followed by a chilled water cooler. No one does this in real-life steady state. You either heat the circulated water or the chill the circulated water. You don’t do both operations simultaneously under steady state operation. Correct me if I am wrong, but I think your operation involves either / or operation of the heating or chilling exchangers. If that is the case, it is important to indicate this on a P&ID and subject it to a Hazop review prior to final design.
I am attaching a copy of the subject ASME article that I converted to a Word document for better reading. I have used this document in prior designs and I consider it a good outline and general technical description of an expansion (or “bladder”) tank. Please note the importance of identifying the proper and safe design pressure. Each expansion tank application is a unique one and should be designed individually. You cannot logically design or describe your specific system using generalized equations or descriptions. That is why a P&ID and a Hazop are required for proper, safe design, installation, and operation. Startup, shutdown, and operating instructions should incorporate Hazop findings. I am not familiar with Pharmaceutical industry design procedures, but I would certainly apply OSHA and standard engineering procedures and practices. For example, consider the worst case scenario for each of the exchanger operations. What is the maximum pressure (and vacuum) possible in each operating case? You certainly should protect the expansion tank (and the closed system) with a pressure relief valve. And this is normally not shown on a PFD such as yours, but on a P&ID. And, as explained, this depends on how you are operating the system and how it is protected.
Understanding Expansion Tanks2.docx 491.7KB
24 downloads
