I am working on vacuum annealing furnace for which thickness to be calculated.The furnace is of Cylindrical
double wall type.Between two walls cooling water flows at 4.5bar pressure.Inside opeating pressure is 3 bar.
My question is to find thickness of shell,
1.Do i need to consider both external(water pressure) and internal pressure separately to find thickness for each pressure and then selecting larger among the two?
Or
2.Calculating the resultant pressure=4.5-3=1.5 bar inside pressure and calculating thickness for this pressure.
What's the right method as per ASME?
