This filter (sketch below) receives a hot (approx. 100 C), saturated slurry (4% w/w) of NaCl and the filter medium is a Nylon woven fabric.
It is not clear to me what you mean with Vacuum (300 - 500 mm Hg). Does that mean that the absolute pressure is 300 - 500 mm Hg? Or that the pressure is 300 - 500 mm Hg below atmospheric?
The boiling point of saturated NaCl solution at 500 mm Hg absolute pressure is less than 100 oC, so if the solution is 100 oC it is to be expected that at the outlet of the filter part of the water will vaporize and consequently some NaCl will crystallize on the backup plate. The deeper the vacuum, the more vaporization and crystallization.
So maybe the choice of vacuum pressure and/or feed temperature could be adjusted to reduce, or eliminate, vaporization and crystallization at the plate holes.
Making the hole diameters bigger will allow longer operation between cleanings, but if the holes are too big the pressure drop over the nylon cloth may push it into the holes and possibly cause cloth tear due to stretching.
Maybe instead of making the hole diameter bigger, it could be better to increase the open area by making new support plates with more 5 mm holes at a smaller pitch than in the present plates.
Or increase the open area by modifying the existing plates to create long rectangular slots, 5 mm wide, X mm long, by cutting away the metal between multiple holes. So two holes plus intermediate distance would become one slot. Or, if hole pitch is small, combine three holes into one slot.
I trust you understand what I mean without a drawing.
Edited by PingPong, 03 December 2015 - 03:23 PM.
