I want to know how to control the interface level in a Waste Condensate Drum in order to have good oil skimming from water. Process drains enter the drum intermittently. Please refer to the attached sketch I prepared for details. Is it possible to have good oil skimming without the interface level control valve on the Water Pump Discharge? The interlock can start the pump at high interface level and stop the pump at low level.
If interface level control valve is needed for better oil water separation, what kind of control valve should be used? Is simple on/off valve ok?
Where is a better location for the interface level transmitter at the water side?
Leo
